Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Greets, through the years I have changed what knife that I use for cutting up stuff at meal time, not talking about your regular silverware. And it usually was my Swiss Army Pioneer blade that I kept for that duty, and then Opinel Slim models were doing the job but recently I have found a regular Opinel #8 mirror polished blade to be about the best, for me at least, for meal time work.
Some have found the abrupt curve edge by the tip to be off-putting and not caring for it but when you use it for slicing and cutting up food, that rounded section at the end of the blade seems ideal type of cutting tool, again, for me at least.
Opinel's have some history of needing to sharpen a few times to get down to the 'real' good heat treated steel, as some figure there are slight burning of the edge during mfg, I don't know how true that is but after a few sharpenings this one does keep it's edge better, so there may be a spark of truth in that.
Untitled by GaryWGraley, on Flickr
That one has padauk handle that I flattened the sides so it doesn't roll in my hand while using and it is more manageable with that little bit of work, I'd recommend it.
So, what is your preferred blade for your meal companion ?
G2
Untitled by GaryWGraley, on FlickrThat one has padauk handle that I flattened the sides so it doesn't roll in my hand while using and it is more manageable with that little bit of work, I'd recommend it.
G2
