Jack O'Neill
- Nov 15, 2007
Hello all , I have to offer here a deep belly skinner I recently finished . Hope you all like it . It has a full flat grind to a near zero edge , then finished with hand sanding to a 600 grit and hand polished with a metal polish to give a very nice smooth satin finish . The edge was then finished with a secondary convex micro bevel to create a screaming sharp edge .
The Nickle Silver finger guard is soldered with 100 % penetration , it is polished on the face and back with a sanded satin finish on the sides . The handle is from a Red Rack from an Elk harvested here in the Pacific Northwest last year , Naselle to be exact .
The Pommel is Mokume Gane from M3composite.com if you need info on the material .
Steel is 3/16" 154CM , heat treated to an Rc. 61
O.A.L is 9-1/4"
Blade tip to guard is 4-1/4" , sharpened edge is at 4" . The belly is at 1-1/4 " wide and 7/8 " at the plunge line
Nickle Silver Guard , Red Elk Stag handle , nickel silver pin , white liners between guard and mokume pommel
Sheath was shaped to follow right hand carry but the knife fits just fine for left hand carry also .
$325.00 shipped in the USA . Pay-pal or postal m/o , check will be held to clear. My PP is sandlot@charter.net
View attachment 639842 View attachment 639843 View attachment 639844 View attachment 639845 View attachment 639846
O.A.L is 9-1/4"
