Hengelo_77
Basic Member
- Mar 2, 2006
How do you guys do it?
Pour in accetone, pour it out and let it dry?
I use mostly wood
I use mostly wood
You could use a brake cleaner / degreaser like that. If it is not enough You can make grooves inside block with rotary bit like here and make several grooves on tang of course.I was thinking, rosewood like cocobolo is oily from itself. Won't that natural oil on the surface of the inside-wood prefent good adhsion?
I fill the slot half full of denatured alcohol, put my thumb over the opening, slosh it back & forth a few times, & drain. I di this until the alcohol comes out clear. It may be overkill but that's the way I've always done it. I think it more of a wash out the dust thing than a degrease thing. Anyway, that's how I do it.
I use acetone for that , and I always for hidden tang mix epoxy with sawdust - shavings from file work . . .. . .How do you guys do it?
I use mostly wood
