DEK1 vs Field Knife
Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
It was recently asked if it would be prudent to baton with a DEK1 and Lorien pointed out it wasn't really designed for that and he might not recommend it.
I have the benefit of a lot of first hand experience in destructive testing all kinds of knives, and Delta 3V in particular, and my perspective is that although it isn't designed for batoning it will tolerate it. You're going to have a really hard time breaking this knife. Also, a swiss army knife will tolerate a little batoning. But it will be more prone to damage than a Field Knife.
But, like Lorien stated, a Field Knife would be a better choice for wood prep for a knife of that size. The DEK1 is .160" blade thickness vs .188. The primary grinds are nearly 10% narrower. It is thinner behind the edge. It has a skinnier thinner point. It is a little more slicy. Not huge differences, but they're there.
And just as important as the blade is the handle. The DEK1 is designed for compact carry (minimal handle size) and a reverse grip. It has specific geometry to key into the interior shape of the inside of your hand in specific grips. The handle is really quite brilliant and needs to be experienced to fully appreciate. This helps it lock in and not slide if you're stabbing something in either a saber or a reverse grip. Saber = held tip up, edge out with the grip across the palm at an angle to project reach. Reverse grip (ice pick grip) = held tip down, edge out with the grip 90 degrees to the arm with the thumb over the butt <--- commonly used in contemporary knife fighting which can resemble grappling.
The Field Knife is not a weapon and does not incorporate a reverse grip. But it does have a larger and longer grip and it accommodates a three finger grip where the butt is in the center of the hollow of your palm (such as when batoning). This handle accommodates a wider range of hand sizes and numerous hand grips used when cutting with a knife as a tool in bushcraft and other extended detailed cutting exercises. You can exert many times more rotational force with this handle than you can a handle designed as stabbing weapon like the DEK1. If you put them in your hand and hold the handle like you would for batoning and try twisting them in your hand the difference is clear.
So, not only does the Field Knife have a somewhat more substantial blade, the handle will resist the rotation and tendency to steer and torque the bevels that leads to bent primary grinds and bevel blowouts.
TL;DR you can baton with either. But less care and skill is required with the Field Knife because the blade is somewhat more robust and the handle is designed to give the user a lot of rotational control which helps protect the blade from damage.
Now, all of that said, there is a lot of overlap here. They're similar size and are made of the same steel with relatively similar geometry and are both intended to be carried as a general purpose cutting tool. The Field Knife makes no concessions for concealability nor does it try to be a weapon but you could certainly conceal it and any knife can be a weapon. And, like the Field Knife, the DEK1 is a very durable high performance cutting tool and it could be used for bush craft, but you'll be able to use the Field knife for more extended cutting chores before your hand and arm gets tired.
I would carry the Field Knife camping. Unless I wanted it to serve self defense. And I would carry the DEK1 as an EDC while mowing the grass in case I get attacked an insane dog attack (this actually happened to someone here on our forum and is why we Deked out an EDC) unless I planned to build a shelter with it afterwards.
They're both outstanding general purpose cutting tools. Choose the DEK1 if you're looking for a more concealable EDC package that doubles as a weapon, and choose the Field Knife if you're going to be cutting a lot of stuff with it all the time like a tradesmen or someone in the woods a lot.
I hope this helps muddy the waters some.
Thank you for that cogent and thorough explanation. My FK1 is my CPK knife for life and I am quite comfortable with that given your explanation. I have publicly said it at least once before and I will reiterate it here—I trust that knife with my life. It is that good. So good in fact that I also picked up an FK2. I will fight knotty wood, prepare camp meals, and engage in other various types of backwoods mayhem all day long with those two knives. However, in the event of a much less likely scenario such as someone showing up to do me harm, I won't be reaching for a knife…not any knife. No offense intended of course!
I would love to see a DEK1 use/abuse to destruction video like was done for the FK. Not because I get my kicks from chit like that, but because I am sure we would be wowed by what this knife will take, and by the actual effort some damage takes.
I’m with you in the OGFK gang.
I’ve yet to put my FK2 to work.
But I bucked up and spent the $49 in shipping to get the fasteners sent here that we’re stuck south of the border and there are plenty of days left in the summer to build fires.
Lots of these differences in my mind are based around the handle. Nathan says the FK2 is some of their best work. I’d like to hear what more owners of both think, because looking at the FK2 vs the DEK this isn’t an either or, it’s both for different uses.
I love me some HDFK too.
I have an HDFK as well, though she has not been used. And my FK2 is very new so is in the same boat. The FK2 is going to see use soon hopefully. I may hang on to the HDFK for when the fan and all the shit that hit it the first time hits a bigger fan with more shit the second time, LOL. :p
The DEK and FK are very different knives. They may have a somewhat similar size but they handle completely different, carry different and fill different roles IMO even though some uses could overlap.
As stated the handle is where I found the biggest difference, not only in feel but in what I can do well with each. I have carried an EDC2 since I got my first and the DEK is the only knife that has found it's way onto my belt for a daily all purpose carry since. To me is more closely resembles the EDC than the FK.
The FK is a great camp knife and did fairly well when I used it a bit during hunting season although I prefer a smaller knife.
The DEK would be a great knife in a last resort defense tool with the added length and blade design and it is nimble enough for everyday uses without being too large, and has the reliability I've come totrust in from CPK. I wouldn't be afraid to push it in a pinch but I wouldn't reach for it to process wood if I had the choice.
I could see using them for similar tasks at times but for anyone thinking they may be to close to one another (admittedly I wondered myself before I got my DEK) they are VERY different knives.
Both are well worth while for me. If I was not an outdoorsman I might lean towards the DEK ... if I did not carry a fixed blade daily or wanted a harder use knife I might chose an FK model. I find great uses for each.
Just one guys opinion ... for what it's worth. If you're on the fence ... you owe it to yourself to get the DEK in hand for yourself.
Nathan the Machinist Nathan the Machinist ,
Thank you for the detailed write-up! Pistols are good for insane dogs, but I worry more about two-legged animals (esp. these days). I currently live in a suburban area that is surrounded by woods and fields, so there is plenty of wildlife including coyotes. A neighbor was walking his small dog in the middle of the day, and was approached by a coyote until he started yelling at it and it ran away; I was surprised the coyote was that brave (it must have thought the dog was lunch :eek:). I walk late at night, and only one time were the coyotes even somewhat close (it was too dark to see them, but I could hear they were much closer than usual).
Nathan,
Thank you for this terrific thread.
However, as they say, no good deed goes unpunished . . . :D
And that is a perfect lead-in for my question . . . and a thread I actually came here to post just now, when I found this thread by Nathan and decided to post my question here instead . . .
What are the major differences between the EDC2 (or EDC3 if you prefer) and the DEK?
I carry my EDC2s on my belt on the regular, and I've been happy with them for general purpose usage. How would the DEK compare to the EDC2 for that role? Are there advantages for the DEK in that role? Disadvantages?
TIA!
Nathan,
TIA!
Size mostly.
We need a Paranee style video to build excitement!
Joe's done me a solid or two, and it's funny reading your post just now as I've recently decided to gift Joe a DEK1
I think he'll appreciate the nuances baked into the design concept, given his keen interest in weapons. He's also a hunter, and DEK1 is also intended for that kind of use, (hence the lanyard dock)
I've never edited any video stuff, but Joe has and maybe he'll give me some advice
yeah. That’s what I was trying to say.
Nathan, seriously though. It really amazes me how different each knife design feels. Before I was told about your knives I really thought that for the most part a knife is a knife. Even though the differences are subtle in design they are profound in use. The FK2 vs. DEK1 is a perfect example. They really are two totally different knives. Then there is the UF which makes you want to stab stuff as soon as you pick it up, again a completely different knife.
