Delica 4 Blade Play
I recently bought a new Delica 4 and I like everything about it but the blade play. It moves up and down, left and right. When I try to tighten the pivot screw, it is either too tight to open/close or it continues to wiggle. Is there a trick that I don't know about or should I return it?
Maybe loosen the lockbar's screw a little bit. Make that one firm, not tight. Then see if there's a middle-ground where your blade will have no play yet still open and close easily.
Thank you. I didn't even think about adjusting other screws (besides the pivot). It locks up tighter and now I don't have to exchange or return it.
Yeah, similar issues occur with any knife with an adjustable stop-pin (and some without).
Glad you like it - the Delica is the "standard" Spyderco you have to have. The Endura is better though :)
Does the Carbon Fiber Delica IV even count for this? It seems to me that with the different grind and scales it would be almost considered a seperater knife from the delica line.
