I'm hoping the collective wisdom of the forum can help me out. I tried to search but the vague description I have gave me the phonebook in results.
So I have a Delica Wave Saber grind that works great. When I press the lockback button to unlock the open blade (in a vertical position), the blade falls maybe 90 degrees before friction stops it. That makes it easy to close one handed (even weak hand which is why I have the waved version). I figured all the Delica's worked this way. The blade is easy to open & close even with my weak hand.
But recently I got a FFG model to see what the buzz was about. Well long story short, the lockback works differently. When I press the lockback (in a vertical position), the blade stays still like the Statue of Liberty. There's quite a bit of friction preventing the blade from moving. Also related if I try to open it with a Spydie drop, with a moderate amount of force it stalls about about 80% open. I cleaned it, blew some compressed air thru it but its about the same. Then I loosened the pivot screw 1/8 turn and it got slightly better but still not where the Wave is. A Spydie drop with moderate force gets to 90-95% open.
So my question is which lockback behavior is normal? Is there supposed to be a difference between the FFG & Saber grind in the lockback?
I'd like to get the FFG version to act like the Waved version. I'm concerned about fussing too much with the screws since I had a bad experience and made things worse once.
Thanks in advance.
Thanks in advance.
