- Jan 21, 2010
Part 1
Well I have been carrying this bad boy on duty for a few weeks now and I think I am finally ready to give an good review. First I just want to start by thanking Andrew for his extremely generous donation of his new hawk for this review. The picture sharing sites are mostly blocked here so you guys will have to make do with the thumbnails until I get that sorted out.
Specs From Demko:
S7 Tool Steel
Differential Heat Treatment
57RC Blade 40RC Handle
Powder Coat Finish
Hand Ground Blade and Spike
Custom Shaped G-10 Scales
JRE Industries Leather Sheath
Weight - 1lb 10oz
Blade Length - 2 7/8"
Overall Length - 16"
Spike Length - 3 1/2"
Head Width - 7"
Thickness - .280"
Fit and finish:
Hands down some of the most comfortable scales I have every felt. The grooves add a great deal to the overall appearance while giving good solid grip traction when swinging, with or without gloves. Surprisingly I haven't had any hotspots on my hands while using it. Haven't made use of the lanyard hole yet but I think i may jus put a loop of 550 cord through it in the not too distant future.
Balance:
It's not as top heavy as you might think. The balance point is just above the scales, making it extremely quick. However hawk is heafty enough for some serious chopping if need be.
Design:
I would have to say the main reason a lot of us carry hawks has more to do with armored vehicles and less to do with 'ghosting tangos'. The vehicles we travel in have doors that can weigh up to 400lbs and are extremely prone to rollover. Pretty much if you do rollover and can't get out through the turret, some cases the vehicles don't even have them, then you are just stuck until someone can come and get you out. The glass is over two inches thick so kicking out the windshield is not an option. You can, however pick and chop your way out if you have a decent hawk with a spike. The spike on the Demko Hawk seems almost designed with that task in mind. It still makes for a devastating weapon, I have no doubt it can puncture kevlar helmets with ease.
I am limited on time so I will have to post Part 2 tomorrow.
http://www.bladeforums.com/forums/showthread.php/977959-Demko-Hawk - stateside pics
http://www.bladeforums.com/forums/showthread.php/974289-Demko-Knives-All-Steel-Tomahawks
Specs From Demko:
S7 Tool Steel
Powder Coat Finish
Weight - 1lb 10oz
Head Width - 7"
Thickness - .280"
Fit and finish:
Balance:
Design:
