- Jan 22, 2007
So what you are saying is that OP basically called out Andrew Demko over nothing, as both locks are mechanically different from what they were being compared to.I swear I posted something on this subject previously, but I can't find it. Anyway, the Superlock is not that mechanically similar to the Shark Lock.
The Superlock functions very similarly to a regular old back lock like a Buck 110.
The difference is that instead of pushing the lock bar down at the butt end of the blade pivot the front of the lock bar off the tang, you are manually lifting/pivoting the front of the lock bar directly.
Here's a video (in Russian) that shows the Superlock (the inset).
The Shark Lock is sort of a cross between the Axis Lock and a Triad Lock.
Instead of a sliding bar, it's a whole assembly that looks very similar to the locking end of the Triad Lock's lock bar.
US10632632B1 - Arm blade engagement lock for folding knife - Google Patents
A folding knife having a blade pivoted from a closed position to an open locked position with a combined self-activating sliding release and locking arm. The sliding locking arm is mounted within the knife handle on dual fixed guide and pivot pins within respective arm openings being spring...patents.google.com
He asked a question in a somewhat accusatory manner. And the title of the thread seems a bit definitive for someone searching for answers. But maybe that's just what happens when nuance is lost on the interwebzOP asked a question, and I provided some relevant sources to inform an answer...
At least with the Shark Lock and Superlock, I think they look similar on a superficial level, with both having a little lever on the spine of the knife that unlocks the blade, but how they work seems to be very different.
I took it that way as well...fwiw.He asked a question in a somewhat accusatory manner. And the title of the thread seems a bit definitive for someone searching for answers. But maybe that's just what happens when nuance is lost on the interwebz
I took it that way too.....He asked a question in a somewhat accusatory manner. And the title of the thread seems a bit definitive for someone searching for answers. But maybe that's just what happens when nuance is lost on the interwebz
Me too !I took it that way too.....
Thank you for posting the video. You're right that it is possible to lift the front end of the Superlock piece like a back lock, but that is not how it unlocks. The Superlock piece unlocks by being moved up but a little more in the direction of the butt of the knife. This disengages it from where it was wedged between a slot in the tang and a pin in the handle. The lifting of the lock bar so that the lock surface is visible shown in the video is a feature for cleaning. The Shark lock is unlocked by moving primarily in the direction of the butt but also up. This disengages it from where it was wedged between a flat spot on the tang and a pin in the handle. A spring in a slot at the back of both lock pieces pushes the lock piece towards the tip of the knife. It is clear that the Shark lock is shorter than the Superlock, but I think the big difference between these locks is that the Shark lock has a closed loop of steel around the pin that the lock is wedged against, but the Superlock only has a piece of steel under that pin.The difference is that instead of pushing the lock bar down at the butt end of the blade pivot the front of the lock bar off the tang, you are manually lifting/pivoting the front of the lock bar directly.
The whole Demko craze has baffled me in general. The dude is importing knives for dirt cheap from foreign manufacturers, made with the same materials you get on gas station knives, and charging equivalent to mid range US producers. His "designs" are definitely not original, though he unfortunately may have been the first to claim them as such. The shark lock is essentially a less practical, less ergonomically friendly axis lock and is very similar to the snecx in it's design, and yea looking at the scorpion lock I'd have to agree it's almost identical with the AG Russel frontlock.
