Dental Surgery by Spyderco
Apologies if this has been shared here before, but my ham-fisted search skills didn’t turn anything up. Further apologies if this should be in the outdoor forum, but given the brand, I thought it would interest not a few.
I’ve been reading Len McDougall’s ‘The Log Cabin’, and came across an interesting passage. Len has split a molar, and when wrenching the two tooth splinters out with pliers, he leaves the roots in situ by default. Having already drained one abscess by painful means, prior to the extraction attempt, he opts to remove the root by himself:
With some trepidation of the unknown, I honed my Spyderco [Native] folding knife to shaving sharpness and prepared to perform oral surgery on myself. I laid the tip against the outer gum, directly over where the dead root lay trapped, and pushed the cutting edge inward through the soft tissue until it stopped against the harder root. I could only imagine what was happening as I operated by feel alone, but I felt the gum separate from around the embedded root. I used the knife to pry tissue away from tooth until the root lay exposed.
Then I went to work with the big linesman’s pliers
Yikes.
That’s pretty bad. I don’t become disgusted easily but rotten teeth and abscess laden gums can ruin Paul Bunyan’s day really fast.
I have a long-term, well-justified and practised distaste for dentists. Even Sal couldn't help those guys.
I got some GOOD teeth.
OT but hope that this helps out the youngins!
If true, then consider them to be worth their weight in gold, literally! I didn't go to visit the dentist much when in my 20's and 30's although I still took care of my teeth by dong the usual home care, regular brushing, flossing, mouthwash... But ultimately it came down to genetics and also being a terrible teeth grinder which did me in round about when I reached my early 40's. Sure, if one has the means then one can buy a whole array of gorgeous white Chiclet looking teeth via implants et al but they're just not strong like natural teeth and are prone to cracking and breaking! Aesthetically it's no fun to have sorta eff'd up jagged looking teeth but if they're good and strong, still better than implants!
Dental implants are anchored in bone and can exert much more pressure than dentures.
