Thanks again guys, really appreciate the feed back.
Jerry, i just take it to 400 grit, then rub it with 0000 steel wool. After i get it glassy smooth, i rub it down with a acetone soaked rag to get the residue off. Then apply a coat of "fixit", let dry buff off.
It takes a while to buff the fixit off, but rub it down with the 0000 steel wool soaked in Birchwood Casey stock wax toward the end and it helps remove the remaining fixit and buffing compound.
After all compound and fixit is gone, i rub it down with a soft cloth and stock wax.
Sounds much more involved than it actually is.
On the 3V ive tinkered with forging some, and it moves ok under the hammer. Problem is figuring out the annealing process.
"Never hit a man unless you must, but if you must, knock him down" Teddy Roosevelt.
www.lameyknives.com
