Someone else posted the plain edge video the other day in another message and I watched it. Then I watched the second part and the two videos on the serrated edge as well.
Comments in no particular order:
I haven't seen a knife shop like that one in nearly 20 years. That is awesome. I would love to visit a store like that! The idea of these two "tests" was very good. Reminds me of some torture tests they do on Glocks... except you can't sharpen a Glock. But I think you know what I mean.
On the plain edge, it's obvious that he brought the edge back relatively quickly, but some things about the technique confuse me. I understand that stage one was just removing a bunch of metal so he could get the chips out. I understand the progression from grit to grit, but how did he determine when to switch? I never saw him touch the edge between grits. I thought you needed to raise a burr on *both* sides with each grit, or you hadn't gotten all the way to the edge.
It's obvious that his technique works though, as it returned to shaving sharpness. I couldn't feel it myself so I don't know if it was "pulling hair" or "popping hair", but it darn sure took off a lot quickly, so it seemed very sharp on video.
I *almost* missed that he put a micro-bevel on it with the sharpmaker. I assume that's what that step was.
Stropping: He used much more speed and force than I would have expected. Again, it worked, so maybe I'm babying my blades a bit too much during stropping.
Oh, my final quibble on the plain edge video: Why the dunk tank of oil? I thought diamond hones could be used dry or with water and that oil (and even water) slowed down the grinding process. Maybe this is just a convenience thing so he never has to clean a loaded hone? ...and from the notes in the video that oil tank and holders were free so...
On the serrated video:
I think you two had two points to make:
1. Serrated edges last longer, period.
2. Serrated edges are just as easy to sharpen as plain.
I have to say that seeing this convinced me of #1. At least good serrated edges. Bust out your Ginsu 2000s and I think the story will be different.
But you were comparing like knives from the same manufacturer, so it was a very fair comparison IMHO.
But (you knew the but was coming right?), I think you failed on #2 badly. First, the technique wasn't explained at all (at least that I could hear over the noise of the grinder and belt sander), and using specialty power tools is hardly "just as easy as a plain edge". Sure, if you've got the shop, got the equipment, and got the technique. But that's hardly a fair comparison IMHO. Sharpen the damaged serrated blade with relatively inexpensive hand tools and I'll be a believer.
I was excited when he started to explain the common mistakes made when sharpening serrations because I've done some of them myself while trying to make a cheap bread knife sharper. But then there was nothing to follow up other than "use power tools like this".
He seemed to really know what he was talking about, and I'll bet if asked he could explain his power tool technique. I just didn't get that from the video and again, I wanted to see it done by hand.
Finally, I LOVE that you had Conan playing on some DVD player in the background. Great backdrop for a knife store and these videos you made!
I hope this doesn't seem overly critical. I enjoyed all of the videos, they just left me with some questions and wanting more.
Brian.
