Because I couldnt find any natural gas forges online as examples to work off of I pretty much had to start this design from scratch. Initially I tried using a venturi a system using the vacuum created by the pressure of the gas to suck in the air needed to get a good flame which I was hoping I could throttle by opening and closing the venture but this was a total failure.
There was some question raised about the pressure of residential natural gas in my last post so I called my gas company and was told that in Ontario where I live the maximum allowable pressure dictated by Government code is 7 inches of water for residential or one quarter of one psi. So it is not surprising that the venturi system was a total failure.
So my system uses piped in natural gas using a 3/8 inch needle valve to control the gas flow and a hairdryer hooked up to a light dimmer switch to control airflow. Dont ask me how an AC motor can be controlled by a rheostat but it works. I also developed a much finer system to control airflow because I realized the best way to maintain a constant temperature is not by manipulating fuel flow but by finely manipulating airflow.
Before I go on anymore about operation I will show the construction which is pretty straightforward.
Here is the shell of my furnace which is just an old piece of 8 inch pipe being cut at work. I actually in retrospect wish I would have gone with a 10 or even 12 inch piece. I only have one 1 layer of insulation and I wish I would have gone bigger so that I could have 2 inches as the outside shell can get pretty warm and it would just be that much more efficient. Also because I make mokume gane and that requires a clamping device I am a little tight for space for that. I went 16" long.
The back plate is quarter inch mild steel which I welded on but left flat on the bottom to work as legs. The front plate is held on by two bolts I welded to the shell which go through the front plate. This way I can easily replace my insulation by removing the front plate. The front door is ¼ inch stainless steel which rides on a pivot bolt and can be opened. If I am doing a knife with a handle I leave the tip of the handle sticking out the slit in the door that way I dont have to open and close the door disturbing the temperature. But when doing folding knives I place them right in the oven and open the door to remove for quenching.
This next photo is after being upgraded with a 3/8 needle valve on the gas line and a 3/4" main pipe upgraded from a 1/2" line.
Heres where I got my fire blanket,
http://www.psh.ca/index.php?cat_id=225. This is the rigidizer I used all my insulation to give it a hard crust. Just pray or painted on and fire up your furnace to set it.
http://www.psh.ca/index.php?item_id=RRIG2
For temperature readout I have this unit,
http://www.amazon.ca/Signstek-Channel-Digital-Thermometer-Thermocouple/dp/B00IZXOLEA and for a probe I use this one HIGH TEMP FLEXIBLE CERAMIC FIBER-INSULATED PROBE Model: WD-08467-64/WD-08467-64-10 found on this website
http://www.thermoworks.com/products/probe/tc_hightemp.html.
I found them very reliable and have used them many times in the last year without failure.
My original design had a half inch vertical pipe assembly for the forced air to enter and a T fitting which went to a ball valve coming off my mainline that I used to throttle the fuel. I was having trouble stabilizing my temperatures so I put a 3/8 needle valve on the fuel line which helped but I was still getting drifting and the temperature didnt seem to correspond proportionately always to my fuel adjustments.
I began to realize that the airflow had a much more direct effect on the temperature than controlling the fuel flow. I regulated my airflow by using a dimmer switch hooked up to my hairdryer but I found the most delicate moves I could make using the dimmer switch often were too large so I realized I had to find a more precise way to control my airflow. It can be done with a hairdryer and dimmer switch but the temperature will bounce back and forth often a larger range than I wanted.
So my solution was I bought a three amp computer case fan and converted a computer power source to drive my computer fan and to control the fan I bought a PWM (pulse-width-modulated) speed controller. This is the site I got mine from but they dont seem to have the 15 amp model I bought anymore.
Http://www.canakit.com/electronic-kits/motor-controllers
My PWM came with a one turn potentiometer that I replaced with this one that I ordered online
http://canada.newark.com/vishay-spectrol/534-11104/wirewound-potentiometer-100kohm/dp/20M1956 which gave me 10 turns of adjustment which was beautiful because this is what allowed me to have very precise flow of air and after this I could stabilize my temperatures within about a 10°F range.
The computer case fan that I used was only a three amp one but there is a four amp and I would definitely go for the extra boost.
http://www.amazon.com/Delta-Electronics-PFB1212UHE-F00-120x120x38mm-connector/dp/B004Y15ALK This is the one I would get in hindsight.
Here is my computer fan with the and PWM with high resolution potentiometer and converted power supply.
So with a half inch air feed pipe and my 3/8 line with needle valve for my fuel supply I was able to get temperatures in the 1950°F range to do my stainless steels and with my PWM speed controller I was able to hold my temperatures within a 10°F range with a little vigilance. And once the temperature stabilizes its pretty easy to hold the temperature like that.
Then along comes my urge to do some s90v which requires a temperature of 2150°F and using my system I couldnt get much over 2000°F. So I increased the diameter of my vertical pipe feeding my air to three quarters of an inch and unfortunately I still couldnt quite reach 2150°F using my computer case fan method. Perhaps if I had the four amp model instead of the three amp I couldve made it but if I want to go that high I have to go back to the hairdryer method. But luckily because I am at such a high range temperatures it seem to stabilize there pretty good even using my dimmer switch method so I have that covered.
I think I am definitely limiting myself in heat and temperature by having a 3/8 inch needle valve for my gas feed. The mainline going to my garage is 1 inch so I definitely am restricting my volume of gas. Apparently doubling the size of a line increases the flow four times so if my gas feed was a three-quarter inch line I would be getting four times as much gas into my furnace.
My setup suits my needs but my point is that anyone wanting to use natural gas for a larger furnace I think could get a lot more heat than I have simply by using a larger diameter gas supply pipe that the 3/8 I am using which of course would need proportionately more forced air of course.
And I have read that natural gas is used in industry to heat treat and actually surface carburize metal so when I heat treat without foil I make sure to run a very rich flame to keep the oxygen in the furnace to a minimum to avoid decarbonization.
https://en.wikipedia.org/wiki/Carburizing. I may be wrong about this but I have never had a problem other than with my s90v with micro-chipping but I believe that is due to using too low of a tempering temperature. And I can tell my flame is very rich because I cut back the air or add gas till I know I have incomplete combustion because I can see flames coming out my front vent in my door.
I find there are a lot of advantages to using residential natural gas opposed to bottled propane. Firstly it is an endless supply and you never have to worry about a bottle running low in the middle of a run. Secondly apparently it costs about one third as much as propane for the equivalent btu's. And thirdly it is less dangerous because unlike propane which is heavier than air and settles in low spots being more vulnerable to explosion natural gas is lighter than air and rises and dissipates.
Anyway I hope someone out there found my presentation interesting and if you have any questions please free to ask.
