Sal Glesser
Moderator
- Dec 27, 1998
Through several dialogues on the forums, I have noticed that there are those that like some mass in their knive and some that do not. I would like to share some thoughts on the question and invite the opinions of the fine minds hangin' out here.
When I was younger, I learned that mass had value in things that did not move (home), or moved in only one direction (flywheel). With things that moved, mass became, in most cases an obstacle as the effort to move the greater mass was generally less efficient than moving less mass. I have thought that way in design.
The most important thing about a knife is that you have it with you (on your person) when you need it. With that in mind, the knife that is the least burden to have with you would have greater value than a knife that created a greater burden when carrying.
The 2nd most important thing about a knife is that it delivers the most possible performance when you do need it. If you carry it to cut and it doesn't, then the carrying becomes wasted engery.
Compromise is an amazing concept and within it lies all of the variation between that "knife which weighs nothing and cuts nothing" and the "knife that weighs 4 lbs and mows down trees.
Add in aesthetics, cost, competition and niches, etc and the variation grows.
One of the reasons this question came up is another thread discussing wire clips.
How much performance are you willing to give up to have something that looks good? Considering the experience of using a knife is personal and focused (unless you are sharing with a friend), would you make the same choice if no one else would ever see the knife?
If a design feature "looked" unappealing, but actually performed better, which way would you lean?
If you were accustomed to a little mass, and the ideal product came along that had everything to extreme, but lacked the mass, would you still purchase it?
Keep in mind that we make hi mass models, such as the stailess variations so we recongnize the need/desire. In a balisong, mass has function in the swing, which requires a certain amount of mass.
Which is your preference and why? A healthy dialog might uncover some truths?
sal
sal
