Im thinking about going 3 routes to get a sharpening set up for carbon steel - white steel and blue steel. Which would give a slightly aggressive, yet polished edge. Are water stones the way to go with Japanese steels or can DMT give them a run for there money in half the time.
1. Diamond DMT Fine/EF. I read its roughly 1k,4k japanese grit. Are diamonds too aggressive even with water to sharpen white or blue steel. This would likely be my one stop solution for the moment if white or blue steel can sharpen with a few strokes and be good to go.
2. Close second - Natural 1k stone, 3k stone. I would like to get something in the middle of aggressive and polished so this is very similar to DMT in grit size if the DMT cant sharpen carbon steel decently.
3. A stone that requires soaking like a shapton pro. What are the differences between a splash and go waterstone vs a soak waterstone.
End use is cutting leather. Less time the better 1-2 minutes for touch up is best. Splash n go is good, no mess is better. Although I wouldn't mind a messier stone for superior cutting performance.
Over time I would likely try diamond, ceramics and natural waterstones but for now want a cost effective solution.
I've asked a few of these questions before but am still undecided. Would DMT F/EF be worth a shot or do I get better performance by using waterstones on carbon steel and taking 2-3 minutes to touch up vs a minute on the dmt extra fine stone (is this about the right time frame to get an working edge).
