Sorry for the mostly related threadjacking, but how do you clean a diamond stone? I have a few old diamond stones (interrupted surface) that are very loaded up, and no amount of scrubbing with clear the swarf. What about swarf that gets into an uninterrupted stone?
I ask because proper cleaning is key to long life, same as pressure control.
If they're really loaded up with swarf, scrub them with some Bar Keepers Friend powder, mixed to a paste with water. Wet the hone with water, then apply the BKF paste and scrub it with a toothbrush or similar. Rinse it thoroughly with running water. The oxalic acid in BKF dissolves iron and the oxides of iron; it's fairly aggressive stuff, so read the directions closely and follow them. Used as a paste with water, it'll be dilute enough to scrub for a minute or two at a time, then rinse it off. If it needs more scrubbing, just apply a little more and repeat. The main risk in using BKF is leaving the undiluted product (powder) sitting on steel too long; it can etch steel. On the nickel coating of the diamond hone, or the plastic, it won't be as aggressive, if at all (except on the embedded swarf). Pretty simple to use it, with some common sense applied.
Edit:
For cleaning diamond hones more regularly, assuming they're not loaded heavily, I just scrub with a toothbrush and some dish detergent (Dawn, Ivory Liquid, Palmolive, etc) & water. Rinse with warm/hot water (speeds up drying), wipe it down and let it air-dry for a bit. If done after each sharpening session (I do), it's a cinch to keep them clean this way.
David
Wouldn't BKF eat away at the diamonds and/or plate? Seems like acid would either eat down the diamonds, or eat away at the plating to loosen them up.
Most nickel plating is very resistant to acids, as are diamonds. Just avoid cleaners with high solvent content and you're fine.
(quoted from -->: http://en.wikipedia.org/wiki/Nickel )
"Because of nickel's slow rate of oxidation at room temperature, it is considered corrosion-resistant. Historically, this has led to its use for plating metals such as iron and brass, coating chemistry equipment, and manufacturing certain alloys that retain a high silvery polish, such as German silver. About 6% of world nickel production is still used for corrosion-resistant pure-nickel plating."
^^This. It's almost inert in most practical uses. The stainless steel plumbing used in industry, in highly corrosive environments, is usually high nickel-content alloy, partly for this reason (it also adds toughness).
And with BKF, the thing to keep in perspective is, the oxalic acid is still a pretty light concentration in this product (5-10% by weight, according to the MSDS). When used as directed with water, it's even more dilute, and can still be used safely and with minimal risk (HEED the directions on the container).
David
