I could be wrong reading others experiences online, but only one milled hole in each liner, lock cutouts have sharp edges and not swoopy edges, no chamfer on lanyard tubes were some of them. But I could be wrong…What makes you think it’s counterfeit?
I didn’t. Bought second hand, despite it was not used at all when purchased.Did you buy it from a reputable dealer?
Agreed. That's the only difference I see as well.The only thing that could be off is that compression lock tab
Good question, I don’t know unfortunately, but could be the case.Agreed. That's the only difference I see as well.
Maybe the original owner modified it for some reason?
Unfortunately it’s a fake. The obvious tell in the G10 handles are the sharp corners of the cut out at the compression lock area; other small fake tells in curvatures of the handles are there too. You can also check your liners; real PM2s have 3 milled holes, and also have the notches in the liners around the middle of the handle (start/stop point of the laser cutting).
Yes, didn’t notice that earlier. A real PM2 wouldn’t have a gap at the ricasso like this.
I'm not sure what is meant by "used", but at a minimum, that knife is sharpened in a way that I have never seen on any Spyderco. And it may just be the angle, but to my eye, the face side pivot screw looks to be slightly rounded as well. A crappy bit could be the culprit or it could be something else.I didn’t. Bought second hand, despite it was not used at all when purchased.
