You removed all that material in less than a year?!
What did you use?
Do you use all three stones when sharpening?
Do you have a strop?
How dull does the knife get prior to sharpening?
What do you do daily with the knife?
Based on the rounded-off tip -- unless it was blunted by use -- I suspect your sharpening technique is a bit off.
im not with ya at all on the rounded tip. pointy knive should be pointy. rounded tip looks odd to me and serves no useful purpose.
- Yep. As per Lansky's own video on their homepage. About 50 strokes per side with the course until I feel the burr. Then repeat the process with the medium and the fine stones.
- No strop. But I strop it against my pants occasionally.
- When it starts to rip standard 80gsm paper or packing tape.
- Not much really. Boxes, packing tape, the occasional ziptie. I'm also a conscript, so when back at the barracks for mandatory training (about two to three weeks every year), it sees usage against gunny sacks and thin nylon ropes.
I quite like the rounded-off tip. Gives the blade a worn down look.
The coarse stone should only really be used when you extensive edge damage, fixing a flat spot, or reprofiling. In most cases, sharpening can be done with a 600 grit stone or similar with a little patience, specifically on that knife you have (a few passes on a white ceramic stone would be more than enough in most instances). The coarse stone eats that super soft 7Cr steel like nothing.Nothing exotic. Just the standard 3-stone Lansky kit. Starting with the coarse --> medium --> fine.
Oh, and on the first sharpening I reprofiled the edge to 20dps, that's all. Well, I was never skilled in sharpening. But at least I can push cut newspaper and magazine pages after every sharpening session.
I suppose the softer mystery steel also plays a part in how much metal was removed each session...
