if you sharpen with the wheel rotating to you, try this and see if it helps. work up a burr on the grit wheel at the angle you want to sharpen at. with the motor off, lay the blade on top of the slotted wheel with the burr up. move the blade back away from you into position as if you were going to remove the burr. watch the gap below the edge and when you see the edge make contact with the wheel, stop. that is the angle you want to hold the blade at. check the other side to make sure its the same. a good light above the wheels helps a lot so you can watch the shadow underneath the blade as you place it into sharpening or buffing position.
