I am curious to hear what types of locking mechanisms show the most wear. I know there are a gazillion factors that cause more or less wear, but which type of lock in your experience has shown the most wear over time.
I own knives with titanium framelocks (steel insert), liner locks, lock backs, compression lock and Tri-Ad lock. I have a chinese made Spyderco ambitious that has seen a lot of use and the liner lock was wearing out to the point where I had to adjust, bent the liner to securely engage the tang of the knife. The lock with the least wear currently is a tri-ad lock. This knife has also seen more use as the mentioned Spyderco Ambitious.
There is a lot of hype around early lockup and often the mention about not being fixated on early lockup because it will never wear to the point where it will compromise lockup, well as mentioned I had a case like that. Maybe just crappy liner steel, but got me thinking.
Also why is there still companies (often high end knives) that does not make use of a steel inserts on their framelock knives. Surely titanium is softer than hardened steel and will wear faster?
