- Sep 18, 2013
I'll start by saying that after messing up 1095 in the past trying for a hamon, I've done a bunch of research.
I've got some of Aldo's 3/32" by 2"1095 and I'm trying to make a 6" funayuki/small gyuto style blade. As much as I'd like to clay up a blade, I realize that I'm not quite ready yet. I took a blade through some thermal cycles tonight and I'm getting much more confident with bringing it up to temp slowly and uniformly. My limiting factor at the moment is budget, which won't allow for Parks 50 or other engineered oils right now.
After some reading, I understand that regardless of clay or no, differential or full hardening, the most important factors are temperature and time. Assuming I can get those to an acceptable precision along with proper blade prep (finish, no stress risers, etc.), is there anything I can do to prevent cracking during quench?
My goal is just to get a good heat treatment to get the foundations down. The blade will be unground, and if I even go for a hardening line it will be unclayed. Despite the thin stock, I'm assuming that supermarket oils are still out of the question, however would a quench in water be enough to get under the curve before moving to oil? Or should I just man up and keep it moving in the water until it's cool? Or am I overthinking everything? I've read a ton of posts on this, but they all have slightly different information and are usually for thicker knives. As always, I appreciate any help. You guys are awesome.
