Before we can discuss the strengths of differentially hardened blades versus fully hardened blades we have to define strength. So, the question is, how do we determine the strength of steel?
Strength in steel is normally measured in tensile or impact strength. Tensile strength is roughly defined as a continous pressure on the blade (like in prying). All steels, depending on the alloy, will have a maximum tensile strength at a certain hardness. As you move away from that hardness, either higher or lower, the tensile strength of the steel drops. Some steels reach their maximum tensile strength at or around 60 rc. But, for most steels it is lower. For the blades where the maximum tensile strength is less than the hardened edge, having a softer spine will increase the toughness of the blade. But, if the hardness of the spine drops too much, then the tensile strength drops accordingly. In some steels, the tensile strength of an edge quenched blade (dead soft spine) could be less than the fully hardened blade. So, all diff. hardening did was weaken the blade.
On the other hand, impact strength is the amount of impact a blade can handle. For the most part, diff. heat treating a blade will almost always increase the impact strength of a blade because the softer the steel becomes the more ductile it becomes. Therefore, it will bend instead of breaking.
Keep in mind that there are very many variables, like steel thickness, hardening method, tempering method, quench method, steel alloy and its hardening depth, etc.
David
David
