Those look like real user's ! I like the handle materials choice and colors too.
I'll bet those cut all darn day.. er week.. er month..
Tostig
Hello Tostig,
Thanks for the post,
It is really weird how some high carbide CPM steels perform, if you manage to put a really course edge on one side and really fine highly polished edge they work fine, also some work well with a polished edge on both sides, but not all. 15v as far as I can tell you works ok both ways but this type of steel was never designed to hold a ‘Hair Popping edge’ it was designed to be used for tooling.
Take care
Nice Knives Farid!
I was wondering how it stacks up to the A11/10V class steels as far as edges. Do you have to run thicker bevels to make up for lesser toughness than the A11 class? How about belt use? I imagine it's easier to work than the Rex 121 you have tried but it still seems pretty wear resistant even in an annealed state. Is it much worse on belts than A11? How about the T1 ?
Thanks for taking the time to share the knowledge Farid!.
Joe/raleigh
Great info, Farid. Thanks for sharing it!Hi Joe,
Ok, first the T-1, This steel has 18% Tungsten so it is around 10% heavier than most steels because of high percentage of (W). provided that it heat-treated correctly it will cut for a very long time and I really like this steel.
REX 121 comes to me at around 57-58RC in the annealed state, you will use lots of ceramic belts, before heat-treating and specially after.
Thicker bevel ? well, in my experience thinner works much better but I know what you are saying. Here is a movie of me using a CPM-10v cutting competition chopper to cut 15mm copper water pipe, this 10v chopper had a thicker edge. I know what you are saying.
http://www.youtube.com/watch?v=lcCjUOp5F2U
Test No-1,
I can only tell you about 15v and REX 121, if you were to test these two steels both the same thickness, the ‘same hardness’ and sharpened to a high polished edge, REX 121 at 68- 70RC and 15v to 64-65RC, the REX 121 would cut a lot longer than 15v. because of its matrix (alloy composition) and hardness.
Test No-2,
If you were to test two blades 15v and REX 121, heat-treat the 15v to full hardness and heat-treat the REX 121 to full hardness which is 71.5RC, although this hardness is not advisable, but as a test the performance of the REX 121 would be in my experience around 40-50% more than 15v.
I wanted to start using CPM-REX 121 because there was no other steel out there which could come anywhere near the hardness and wear resistance, not easy to work with before or after heat-treating.
Take care
Thank you sir, I am more and more going towards simple designs,I'm not much of a steel guy, Farid, but damn those are some fine-lookin' knives! Such beautiful 'clean' & uncluttered simplicity... very nice work, sir! :thumbup:
I think thats the record for biggest fuzz stick ever! Great looking knives sir. Is there anything you havent tried yet or something new you are looking at?
There was one thing I wanted to do which still haven’t done yet, go to a car scrap yard with the CPM-REX 121 chopper, ask permission if I can choose a car and cut the whole roof in half. Just for fun.
An old car, back when they used to make them out of steel.
Not aluminum foil and plastic...
