- Oct 9, 2008
A couple of days ago I was tempering some blades in my Evenheat furnace. I had set the controller for 400 degrees and 2 hours. I verified it settled at 400 before moving on to other things. While I was elsewhere, my wife decided to fire up the mitre saw to cut some trim. It was plugged in to a 110 outlet close to the 220 I use for the furnace. I happened to look over at the furnace after about an hour and saw it was at 460 degrees, well above my setting, and slowly cooling. Since it had never done this before in hundreds of sessions I was concerned something had failed in the controller.
After thinking awhile, I decided to try a test. In another life, I was a mechanical engineer designing equipment for satellites, rockets, space shuttle, etc. One thing that we had to deal with was electrical interference from other equipment, particularly high power stuff. The electrical noise could be conducted down power lines or radiated from the other equipment and cause all sorts of strange problems. Since my wife had been running the saw, I turned the furnace on, set it for 400 and let it settle. Then I started the saw a few times and sure enough, after 5 or 6 trys, the furnace started heating beyond the set point. I have since run it several times with no problems at all so I an convinced the electrical noise generated by the saw caused a problem in the controller. Whether conducted or radiated, I don't know, but it definitely caused it to behave badly. So, if you have an Evenheat, I recommend being cautious when you are running something else at the same time. Fortunately, my blades tested fine but it could have been ugly.
Randy
Randy
