Ok bascially, I'm going through that phase where I must have another knife (I'm sure you've all been there) and I'm looking for some reasoning in my choice.
Be brutal in your opinons I like to hear every little niggle / issue with something before I buy it.
I've narrowed the choice down too 2 knives namley;
- Spyderco Delica Carbon fibre (plain edge)
- Al Mar Sere 2K
(While you're probably thinking, "those are two totally different types of knives" please read on as this is where the poser is).
My Dilemma arises as I have two requirments to fill and can only really afford one knife;
- EDC
I'd like an exceptionally sharp, low profile and tastefully sheeple friendly knife that could nestle around my person for use throughout my day to day life (must have a good strong pocket clip).
Tasks will be mostly opening boxes, packaging and plastic parcel tape (hence good cutter) and the things an EDC would be used for (removing splinters etc).
It should be easy to open one handed.
As I say it must be rather sheeple friendly with a blade 3" or under, as I'm a resident of the UK where anything over that is illegal without very good reason (This is a reason why the SERE would not be viable).
NB, Self defence is not a consideration.
- Field utility
This would be less used (once a fortnight) I'd require a sturdy knife to cut myself out of brambles when I inevitebly get tangled, clear a small area to shoot through and general small field tasks (the axe mentioned below is not viable in this situation).
This knife would also be used when back backing / hiking once a quarter (for a week or more) for general camp tasks such as cutting light brush, 550 cord and preparing food. For heavier purposes (such as shelter building) it would be supplemented by a Gerber Axe so would most likley do very little chopping.
My own thoughts (I'm using this thread as a train of thought more than anything else);
- Since I'd be carrying the Spyderco every single day it will see a hell of alot more useage than the SERE, and therefore it makes sence to have the higher quality knife where It'll yield the greatest benifit (rather than the occasional use of the SERE).
- While I already have quite a light-weight axe that can tackle the heavier work and I might just about get away with using the Delica to tackle the rest of the camp chores, I'm unsure if it would be suitable for a field utility knife without the backup of the axe. Do you think it would manage the tasks described above without adverse effects
Anyway thats my thoughts on the situation, whats your take ?
All and any opinions appreciated, as are alternative knife suggestion.
Cheers
- Al Mar Sere 2K
- EDC
- Field utility
Cheers
