Diomedes Industries - Preoteus Fishing Kits - PRICE REDUCTION!
Feedback: +36 / =0 / -0
The container is made of hard plastic, water tight (I add a ranger band to ensure your kit is water tight), holds the entire kit, and works as a expedient reel and rod. Wrapped around this tube is a yard of red duct tape. We all know how great duct tape is! This type of fishing used to be called Hobo or Hand fishing - and after an extensive test this summer - it works! At various lakes this summer I was catching as much or more as the other fisherman with poles and full tackle boxes. Simply underhand or sling cast your line out (I can get this rig to cast a full 25 yards!) and let the weight, hook, and bait fall to desired depth to start fishing.
The kit comes ready to fish with approx 30 yards of 12 pound test red or smoke green fishing line tied (arbor knot at the top to prevent slipping at full cast) and wrapped around the top of the kit. It is held in place by a 'ranger band'. There is a bobber knot/bead, premium E-Z Float, two sinkers and a Eagle Talon hook tied (improved hook knot) at the end. Simply add bait (supplied) and you are fishing in a matter of seconds.
Inside the kit comes with 24 pieces of artificial bait (pink and chartgruse) in a sealed baggie in case you cannot find bait in your situation.
Also included in another bag is:
1) 5 Assorted hooks: 2 size 10 gold and 3 size 12 bait holder hooks.
2) 10 or more split shot sinkers
3) 2 Treble hooks for drop lines.
4) 2 curly tail lures (3/8th ounce waited head)
5) 9 curly tail lure replacements (3 different colors: Chartreuse & Black, Pumpkin Seed, Blue & Silver translucent)
6) 2 pre-tied bobber knots and beads.
7) A screw eye to make an expedient fishing pole out of in the field.
8) A spare Ranger bands for the kit.
But that is not all! ;)
I have included a bobbin filled with 60+ feet of 30 pound test spyder wire! This no memory blend can be used for a dedicated fishing pole (use the eye hook above, a long stick, your extra bobber, bobber knot, sinkers, and hooks) and you will have a great dedicated pole. If two of you are in a survival situation, you can double your odds with this addition to your kit.
You can also use this line for additional drop lines. You will be fishing in multiple spots in multiple places
I will also include a full set of instructions with knots (4 pages), directions for use, and ideas for supplementing your kit while in the bush.
All of the equipment is top notch and fully tested!
23 paypalled, and shipped
Order more than one - and every additional kit is 21 dollars.
Thanks,
TF
paypal jmoulenbelt (at) hotmail (dot) com
