Direware S-96, Graham GL Razel, Dustin Snyder Echo, Trouble Blades Mini MOFO, Will Moon Stormcrow
ShadyMethods
Platinum Member
Feedback: +320 / =0 / -1
If you have any questions about what's listed, just let me know and I'll do my best to help you out. For more details, specs, or pictures, ask and ye shall receive. You can reach me through private message or through my email: kenleung1995 at hotmail dot com. I also check my threads fairly often so I'll see your posts. I can work with you on the price for some of these and I'm open to trades. Prices include all shipping and PayPal fees in the US. I'll be happy to ship international but the buyer will need to assume all risks and help cover the cost of shipping. Thanks for your time.
For trades, I'm looking for: Jon Grahams, Yunas, Marlowes, Direwares, GTCs, TuffKnives, Sharknivcos, RJ Martins, Rocksteads, Dalibors, Broadwells, Black Snow Customs, Phantom Steelworks, Kirby Lamberts, Jim Burkes, Ochs, Blackwoods, VanderMeulens, Goodwyns, Rogovets, Jason Clarks, Rassentis, some Shirogorovs, Grimsmos, Brown Knives Servo, Jason Guthries, ZT 0454, CKF Terra, and maybe a custom Emerson or just Striders in general but if you have other offers, I'm happy to hear them. Cash can be added either way.
1. Direware S-96 - like new - $925
Slightly smaller than the Solo but just as tough
2-tone M390 non-recurve blade
Blade has a stonewashed satin on the flats and a satin on the grinds
The front handle slab is a big piece of contoured and polished original marble carbon fiber
Blasted ti lockside
Glass smooth action with a nice snappy detent
Not yet completely broken in but already drops shut
Centering and lockup are perfect
2. Graham Knives Custom GL Razel - like new - $1100
Slightly older version running on phosphor bronze washers
Thinnest blade stock I've seen Jon use
It's paper thin behind the edge and still has Jon's edge so it's a lightsaber, even slices with the razel tip
Blackwashed and Bos heat treated CPM-154CM blade with his signature grind
Show side is lightly textured brown G-10
Lock side has a bronzed working finish
Not 100% broken in so it occasionally has lock stick
Runs smooth and has an impressive action
Centering is perfect and it locks with zero play in any direction
Handle is contoured and very comfortable in hand
3. Dustin Snyder Echo - near mint - $750
Well built Small Sebenza 21 sized custom that's slim and disappears in the pocket
Frame has been contoured and has milling on both sides
Black timascus clip
Runs glass smooth on bearings and the blade will drop shut
Locks up rock solid and centering very close to perfect
4. Trouble Blades Mini MOFO - like new - $800
EDC sized version that's slightly smaller than an SnG
Blackwashed CRU-WEAR blade that measures 3.25"
Flamed bronze ti frame with frag pattern milling
Polished pivot and stop pin
Backspacer is sandwiched between 2 copper liners
Still very new so it hasn't had a chance to break in
Well centered and locks securely
5. Will Moon Stormcrow - near mint - $500
Upgraded with a CPM-20CV tanto blade
2-tone hand satin blade with a mirror satin on the flats
Black frame with the new clamshell construction
Blasted inset linerlock and Begg-style clip
Runs smooth on caged bearings and flips well
There is some slight blade play that might go away as the knife breaks in
Blade sits well centered
