I have just joined this forum and this thread is one of the first I have read. It prompted me to look at my 2 shapemakers. I have a 5 year old one that has only the 20 degree bevel and a 1 year old one with both 15 and 20 degrees. The max warpage in the white stones is less than half a mm in 180 mm. This is acceptable for a sintered product and would not produce an error in sharpening. The brown stones on the newer set are similar. But there is noticeable wear on the brown stones in the older set. About 1 mm in 90 mm on the corners of the triangle. The flats appear unworn. This amount of wear would be about half a degree variation from the stated angle. Given that the stones are a loose fit in the base, then the edge may be getting to the factory tolerance of +/- 1 degree. I will keep an eye on the wear on the older set as it may be coming time for a replacement set of brown stones. Some quick calcs leads me to believe that it may tolerate another mm of wear but no more.
If your original set of stones are within the same measurements as mine then I would be more concerned about long term wear on the softer stones. As an aside, I am a retired professional mechanical engineer and it seems to me that, as these are a uniform shape and size, then it should be possible for the factory to use an automatic gauging system to remove the obviously warped stones. The stones that prompted this thread were obviously warped to the naked eye and a gauge system would remove these from the suppply chain. Unfortunately, even then, some defects will get through. Which is why manufactuers have a return policy. Given all that, I am quite satisfied with the shapemaker as it creates a good edge and others in my family can use it. Takes the load off me in keeping the kitchen knives sharp. It gets a thumbs up from me.
