Disc Grinder paper
I was wondering if anyone knows if I can buy Resin bond Aluminum oxide closed coat paper in bulk rolls (different grits) I designed and am building a Disc Grinder with interchangable 9" disc plates in flat and bevel, and want some of this paper for the flat plates. I found some for an angle grinder, but it has a hole in the center of it.
I use the AO 60, 120 norton blaster 9 x 11 at Home Depot. This AO paper lasts a long time. 220 on up I use the Norton SC from MSC and buy only when it's on sale.
Using 9"discs you can use standard paper and trim to size.
Stan
Rod
Do you have any plates for your disc grinder. I am finding I could use 2 more for different grits. It sure saves a ton of time changing paper and eliminates wasting paper.
rnielsen, i use the discs with the holes in the center and they work just fine. i use a good brand of spray adhesive to stick them to the disc and let them sit overnight. what kind of price are on the ones you found? the cheapest i found for 24 grit were $1. each.
I paid about $2 each for them
I was looking for a bulk roll so it would not have the center hole and I could trim the outside.
I designed and built a disc grinder with interchangeable plates (can use seveal different 9"discs on one motor) its really handy, and I just wanted some sturdy heavy grit paper on some of the disks(check out the website on my profile)
