- Nov 24, 1999
I have a 6" bench grinder I can use, but I don't like it very well because there is hardly any clearance between the wheel and the motor so you have to make very short blades.I have a delta 4x36" belt sander with a 6" disk on the side. It puts out 1/5 horsepower. Would I be able to do the profiling and rough grinding on the disk, then switch to the belt to finish it up? I will be working with blanchard gound ATS34. Any other suggestions?Thanks alot.
Fix it right the first time, use Baling Wire !
