- Apr 18, 2020
So can mineral oil be used in the pivot of folding knives, or is 3 in 1 oil ok? I don't use my knives for food alot.
Most vegetable oils turn rancid after some period of time of being exposed to air. So they aren't a good lubricant or protectant for knives. Mineral oil is food safe and is not from animals or vegetables and won't turn rancid.
Brian.
WD40 is the stickiest crap I've ever seen besides adhesive. Did you never try it on your bicycle chain when you were a kid? I did once, and I have never used WD40 for anything else my entire life except to unstick rusted nuts and bolts. Period.
I'll consider that a joke. I don't even use WD40 so I am surely not going to eat it...
I haven't used CLP for anything since I left the military. No use for the stuff. WD40 isn't even considered a good lubricant for most applications. WD40 works great for what was stated. Period.
It's not a joke.
WD 40 is not sticky, it does not attract dust, and when the carrier evaporates what is left is just mineral oil.
Now, 000Robert might be an expert on WD 40- but I have been using it for 50 years. I use it in my cutlery shop, on guns, used it as a steam and refrigeration engineer, and I even use it on my guitar strings. You would think I would have seen some of that stickiness or gummyness. I have a 9 year old squirt bottle of WD 40 that the carrier long ago evaporated out of. There is just mineral oil left.
What I have seen, is people using it improperly-diluting grease or mixing it with old oil and dirt.
I think what bill said is true. It will go sticky and yuck if the surface you have put it on has old grease or oil. If the surface is clean it will be fine. I'm taking his word for it as he's been using it for a long time.It must be a different kind of WD40 than is in the regular WD40 spray cans.
Did you shake the can first? Gotta follow the instructions...WD40 is the stickiest crap I've ever seen besides adhesive. Did you never try it on your bicycle chain when you were a kid? I did once, and I have never used WD40 for anything else my entire life except to unstick rusted nuts and bolts. Period.
No one said to use it as a lubricant. We said it was a water displacing agent. It also leaves rust protection in areas that are otherwise inaccessible.
WD 40 is a lubricant, but it's just light mineral oil.
I like break free also, and have used that and WD40 interchangeably for years on knives. WD40 definitely tastes better, though. In a blind taste test I'm sure you'd agree.Compressed air and heat will remove water. And I have Break Free for rust prevention and lubrication. So, I'm set.![]()
I read this too quickly and thought you'd come up with a new use for ale.
"See honey, it's not just for drinking..."
