What strap is that? Looks interesting.that delta hydra is a hell of a deal, the watch is very well made, the band is not as well done, I replaced the clasp with a ratchet clasp and now im wearing it on a strap more, the copper protrusion on the upper right is a HRV valve instead of a bezel lock like the proprof or ocean7
View attachment 2044921View attachment 2044922
its a copy of the old Hirsch extreme made by deepblue watches for alot less money. still fkm rubber not siliconeWhat strap is that? Looks interesting.
Yup, and last I checked Luminox won't replace tritium anymore...that's what started my hunt that ended with Raymond over at Bonding Co.In case anyone is wondering what happens to tritium gas tubes after about 20 years or so . . .
Tried taking a pic in a completely dark room, but you couldn't see the older Luminox at all.
Experiment with face up, face down, crown up, and crown down. You might find one that runs fast (I have on several of my watches). Once you figure that out (assuming you keep records of position and drift), you might be able to keep it almost dead on my varying how you rest it overnight.Been checking the accuracy my Islander Northport with the Miyota 9015 movement. Set to and checked against the NIST.
1st three days, wearing it all the time: -14 seconds or -4.66 seconds per day so I set it to exactly 1 minute fast so I could check it over time; it should slowly lose time till it's right on then start going minus, Theoretically I should only need to re-set once a month or so and never be more than a minute off.
Per advice I saw on line, I removed the watch at night leaving it stem up. After another 3 days it's -7 seconds or -2.33 seconds per day. This is well within the specs for the Miyota movement and I am happy with the results. I guess it's true that position effects accuracy on mechanicals.
I'll continue with the watch off at night and re-check over time to see how it holds up over longer periods.
