It is a flanged bearing with those dimensions. You would need whatever the caster you use comes with though, and it varies from wheel to wheel.
The tracking is rock solid from the tape around the contact wheel. If you remove the tape for hollow grinds, then you can adjust the 4-40 screws on the 1.5" tube. Tighten the right sides and loosen the left or vice versa to adjust the tracking. Slow and tedious, but effective and cheap. I thing I can redesign it to be easier. Give me a few days.
I should note that the 1 1/4" tube can be cut to length. I can extend it enough to use a 4" caster or shorten it enough to use a 12". Also, place magnets underneath the bottom of the belt/top of the base to pick up the metal shavings. It works great and lower the dust.
I love this conversion because it allows you to use the great quality 2x72 belts at such a low cost. The real key was figuring out the casters. I started with a lawn mower wheel and it worked for about 30 seconds. The casters were marginally better until I replaced the bearings.
Where did you get the 3/16" x 1/2" lip bearings.
Billydarrinmitchell@gmail.com
Anybody have pics of this conversion?
