DIY Air Tank Propane Forge Regulator????
Doing my homework on a DIY forge. I have no idea what type regulator will work for a standard USA propane tank. Please point me in the right direction. I assume it will need to be adjustable, any where from 0 psi to approx 20 psi TY
I got mine from here a long time ago (10 years I think) and it's been great. It's just now starting to act up. But I have been happy with it. I have the 0-30psi with the 5ft hose. I should have gotten the 10ft hose. Also there quick attach/detach connectors are nice. I use one on both of my burners so I can switch the gas line from one forge to the other.
http://www.hightemptools.com/propaneregulators.html
One thing I did on mine which makes it nice and easy to know how much gas is left in the tank, is I put a high pressure gauge before the regulator. Advanced auto sells one that has a shut off valve on it about like the one in the image in the air tool section. Think it's around $10 or $15. I also have my line pressure gauge up closer to the burner.
edit: I also have the 0-30psi regulator.
