laser button/switch exposed
small "v" notches for every 2.5 degree angular change. Larger notches are 5 degree increments, with smaller notches at 2.5 degree increments in between.
Alternatively, I can make and print a scale on a piece of paper (I designed the goniometer to have a circumference that equates to 1mm for every 2 degrees of laser deflection so making a paper scale should be easy enough. I think I prefer the notches in the plastic to a paper scale, because they can never get dirty or get damaged.
Total size will be about 12.5cm x 12cm.
Any thoughts or inputs from you guys, feel free to comment!
Hi,
My first thought upon seeing the full sized pictures is, can you make it into a whistle?
Or better yet an ocarina flute?
A binder clip should grab onto blade about 5mm-10mm deep
If the goniometer can accept a binder clip,
for example 1-3 slits on the bottom
so the gonio sits on the binder clip,
leaves one hand free to take a pictures
Notches are good, but what about vertical grooves as well?
like grooves on a speed/rafter square, that user can fill in with crayon?
Classic hack for a laser pointer is a zip-tie as an always-on switch.
You could have always-on by pushing the laserpointer slightly forward,
or add a left/right slide button to depress the laserpointer button
Why circular instead of boxy? Makes each degree equidistant, but is that important?
1mm for every 2 degrees? Thats a small circle
Given circumference (C) = 180 says that makes diameter 57.295779513082,
shouldn't that be
diameter be 120mm making 1mm for every 1 degree or?
If you dont taper the handle , if you use a lip as a handle, you can expand the radius,
but yeah moving parts are complexity
with 3 telescoping parts it can collapse by half
