Would using 220 work better ?V-IR
120=Ix20
I= 6 amps
P=VI 720 watts
That won't get hot enough. To reach 2000°F you need around 13amps to get 1550 watts on 120VAC. That would require a coil with around 9 ohms.
probably but i don't have access to it.Would using 220 work better ?
The wattage is only one part of the equation, a lot will depend on the size of the furnace and on insulation. What is the volume of your chamber?so if i shorten the coil, will that work? if not what can i do to reach that temp?
thanks for your reply
18" long x 6" tall sidesThe wattage is only one part of the equation, a lot will depend on the size of the furnace and on insulation. What is the volume of your chamber?
How wide is it on the inside? Take a look at Dan Comeau's page about DIY heat treat ovens if you have not already. He has a table showing wattage per cubic foot for common heat treat ovens. I think the one I built has about 7kW/ft^3. I don't recall the exact time it takes to get to the temperature you are looking for, but I typically plan to let it preheat for at least an hour for AEB-L.18" long x 6" tall sides
those dimensions are the insideHow wide is it on the inside? Take a look at Dan Comeau's page about DIY heat treat ovens if you have not already. He has a table showing wattage per cubic foot for common heat treat ovens. I think the one I built has about 7kW/ft^3. I don't recall the exact time it takes to get to the temperature you are looking for, but I typically plan to let it preheat for at least an hour for AEB-L.
Sorry about the misunderstanding. You only gave the internal length and height, not enough to compute the volume. That's why I asked about the width on the inside.those dimensions are the inside
sorry man, My wife says that my communication skills suck! 18 inches long and 6 inches on the sides the back, front and width.Sorry about the misunderstanding. You only gave the internal length and height, not enough to compute the volume. That's why I asked about the width on the inside.
Of course, plugging into a different outlet does not change the current draw of a device, that goes without saying. I suggested to look for a 20 Amp outlet so the OP can design his coil to draw more current. I am not an electrician, but the 16 A draw you suggest seems too high for a typical 15 A outlet.Texas has 220. Check the breaker box. You might have to add an outlet, but the panel is almost surely 220.
Hubert ( and others),
Plugging into a 20 amp outlet does not deliver 20 amps to a device. The device will only draw the current that is required by its resistance. Plug in a 100 watt light bulb and it will draw .83 amp. Plug in a 1000 watt heater and it will draw 8.33 amps. His coil is 20 ohms, which will draw only 6 amps regardless of where it s plugged in.
Shortening the coil by half will cut the resistance by half, and double the amps - which should work, if he wound the coil at the right size.
Normally, it is best to order a pre-wound coil that has a desired resistance and length. 15 to 17 gauge is the right size wire for most HT oven builds. You want a coil that draws around 16 amps for a 120VAC oven.
WOW. thanks.Ok, so your volume is 0.375 ft^3. If you go with Stacy's suggestion above, you'll be around 4 kW/ft^3. I guess that can work with good insulation, but it is on the low end of commercial offerings. I would not expect it to be really fast and it may struggle to get to the 2,000°F you are targeting. Do you have any 20 Amp outlets? They look like regular outlets, but have one T-slot, see picture from wikipedia.org below (that picture is upside down compared to what you'll typically see in a house in the US). With that you could get a little more power without a 220 V outlet. The downside to doing that is that you increase the surface load on the elements and they might not last as long.
Search little here , you will find lot of thread of nice DIY HT oven build by members .......WOW. thanks.
