- Jan 1, 2018
I was asked to put something together on my heat treat oven so I'l try to provide some of the details and issues I ran into. This will be long so I'll try to break it up into sections. This project isn’t nearly as complicated as you might think and you can build an oven for 1/3 the price of buying one. I will post a you tube video of the oven Here:
Heres some pics of the oven.
https://flic.kr/s/aHskx6ZK6Z
First off, I give all credit to Dan Comeau Custom knives. He has an incredible site with all kinds of builds that are extremely detailed. For this build he even has an excel sheet to calculate you coil design so thanks to Dan for this. I'm a Civil Engineer, not electrical so if I made a mistake anywhere, please feel free to correct me.
I am Canadian but will use imperial measurements as it seems that it's mostly Yanks on here. Prices will be in CAD and Temperatures in F.
I designed this oven to be 240 volt and to run at 3000 watt. With a single element, this draws 12.5 amps (calculated) with a given wire resistance of 19.2 ohms. The internal dimensions are 14.5" by 7.5" by 6" high. I should be able to treat a 16" blade diagonally. This gives an internal area of 0.377 cu ft. At 3000 Watts. this about 8000 watts per cu ft. This is a bit overkill but I didn't want to have to wait an hour for it to heat up. It takes about 15 minutes to reach 1900 degrees F. The total cost of the oven was about $400.00 CAD plus Tax so close to $500.00
I bought the insulating firebrick and Kenthal Wire from the Pottery Supply House in Oakville Ontario.
https://www.psh.ca/.
Here’s an Amazon Link
https://www.amazon.com/Amaco-28035N...=8-2-fkmr0&keywords=insulating+fire+brick+k24
It cost about $200 for 24 bricks and 150ft of 16 ga kenthal wire. This is almost 3 times the amount of wire I needed but it was good that I bought extra. For the Firebricks, I used K23 9x4.5x2.5. This was the most expensive part of the build. Youmay want to buy a couple extra brick because they chip and break easily.
Oven Design First steps:
First you need to decide what your available power is. 120 or 240v. Then decide how many amps you can deliver. 240v uses 1/2 the amperage. I wanted about 3000 watts so I decided on 240v at 12.5 amps. Dan’s site has a chart that shows commercial ovens and compares their wattage to internal volume. These average about 5500 watts per cu ft. I decided on 3000 watts and wanted roughly 8000 watts per cu ft so I needed about 0.377 cu ft. I went high on the wattage as I figured my oven may not seal as well as a commercial unit so I'd compensated with more power. Dan's site has a calculator you can download to figure all this out. Keep in mind that if you use 2 elements in his calculator, it gives you the length of wire for only 1 element.
Also keep in mind that there is a relationship between your wattage and internal volume that will limit your design. I had first intended to use 2-3 elements in parallel in case one burned out, I didn't need to replace them all. However, as resistance is calculated as 1/(1/R1+1/R2+1/R3) every element you add essentially lowers the resistance by a factor. Two elements in parallel have half the resistance of one element. 3 would have a third. Wattage increases as resistance goes down. This may seem counter intuitive but a five foot element would have twice the wattage as a 10 foot element due to the fact that there is less total resistance. Say you decide to use 3 elements. The resistance in each element needs to be 3 times more than a single element to make the same total resistance. Multiply this by 3 elements and you have 9 times the amount of wire. You may run into a problem where your oven simply doesn't have enough room for all the elements. This is why I ultimately decided on a single element of this design.
240v
3000 watts
12.5 amps
19.2 Ohms Resistance
resistance for 16 ga wire is 0.324 Ohms per ft so I needed 59 ft of wire.
If I were to use 2 elements I'd need 118 ft per element or 236 ft of wire.
If I were to use 3 elements I'd need 177 ft per element or 530 ft or wire.
I hope this makes sense. Using a heavier gauge wire means that you need more as well because the resistance per foot drops. Same principal as above.
You may ask, if elements in parallel have to be longer, than what’s the advantage? Having elements in parallel means that each element is using less watts per length than a single element. 3 elements would use the same power but would be 9 times longer so they should last much longer. You may also get more even heating by having more elements in the oven. I didn’t think this was an issue as the elements are fairly easy to make and install.
240v
3000 watts
12.5 amps
