- Jun 3, 2019
THAT is a great idea. Thanks!If the Corby is oversize chuck it up in the drill press and touch it with a File or Sandpaper wrapped over the File or block of wood while its spinning.
Ah you finally got it...Yes I'm responding to EXACTLY what YOU wrote on the INTERNET...interpreting a few casual words. Next time be Precise then there will be no need to go back and clarify your statements...Trusting what you read on the Internet is Sketchy at best...YMMVMan ... you are drastically over-interpreting a few casual words. the results were perfect ... I could not have expected anything better ... I was amazed at just how beautifully the fit to the handle worked out. Does that help clarify??![]()
Yeah I know I'm not as smart as I look, but I do have a few tricks up my sleeve...and You're WelcomeTHAT is a great idea. Thanks!
That is exactly what serious and professional knife maker will do .They will find RIGHT one for Corby bolt in several of them they purchase ... Look I like what you done , probably no one here does not improvise as much as me .But I do that for me .If I work on knife which I will sell with material I pay for , I don t think that I will improvise like I do on this picture .Do you recognize that toolmy posts not that long. others as long or longer.
$500 Mammoth scale (you mean tooth)? probably not. But I also would not use a purchased tool without checking it first.
At the risk of re-opening this thread :-( .... Busto - I just had a chance to try your thought of putting the slightly oversized Corby into the drill press and sanding it down to diameter with sandpaper. Worked like a charm! Thank you again for the idea!If the Corby is oversize chuck it up in the drill press and touch it with a File or Sandpaper wrapped over the File or block of wood while its spinning.
You're Welcome...30 years as a machinist I learned a trick or two![]()
