It s time to say again.....this is the last grinder i will make
I have six of this linear bearing set , about 18 inch long .And two set long about 60 inch. I got them a long time ago, I wanted to make a CNC grinder.....no way ! They are very expensive and best quality .Now it s time to make use of them ...........surface grinder ! I have tons of quality ball bearing , i have gas forge I even have small anvil and hammers of course ........
But after I straighten ball bearing race they need to be surface ground ....so here we are
Plan is this ...........I will make/use belt grinder / 2x42 belt /for feeding , one set of this linear set is more then enough for sliding part .What I m not sure if I need to do is ..........do you think that If i grind part by part / will be better-faster / I mean grinding like real surface grinder ? Or should I make it fixed ? Which make building much simple and grind whole steel at once ?
I will use 2HP 2800 RPM motor with 7-8 inch wheels, rubber and hard surface .
What do you think ? I kind of cheer for the first solution...to make use of that lathe part
I don t need anymore jig for hollow grind
One more question......home made plate with magnets or real one ?
