I promise , if I need to drill and tap one more hole in this thing ............it will end in scrap yard !!
I had to move the handle so I can use holes for handle / I tap M10 thread there / for adjusting angle on chuck .........
Last update .....................I hope !
I solve heating problem , Al plate are 10mm. thick , magnets are also 10mm so i needed little clearance and used that Micarta to add thickness......I honestly didn't even think about the temperature then.That micarta there was an insulator for heat... So I make new part/2.5mm thick/ from hardened steel ,48-50 Hrc. Drilling all that 27 holes was not fun at all , especially because I had to use 10mm drill bit directly through the Al plate holes to keep them aligned ...Now I have 45 mm thick metal under blade so heat can pass down...........
I also made an accessory so I can taper tang or blade , simple solution .I think it should work nice .............Unlock chuck , turn that two screw to lift chuck from that side ,lock nuts on them to fix them and grind that taper .....
new steel plate to replace Micarta one
back side of chuck.................
