According to this article there is an improvement in corrosion resistance in the use of DLC in desalination plant when applied to 316 stainless:
https://www.sciencedirect.com/science/article/pii/S0011916416317167
That is a strange claim to make, given what we learned about DLC
promoting rust on actual
stainless (while leaving uncoated steel areas pristine no less!) on this other thread...:
https://www.bladeforums.com/threads/what-the-rusty-blade-coatings-explain-please.1112532/page-2
This lead to the hilarious defense that these particular coatings were
never meant to protect from rust, but were
only to cut reflective glare. I kid you not.
In that thread you could also read these hilarious posts:
So you're saying rust is what? A frame of mind? It will only develop if you worry about it?
I sure wish I knew that when I lived on the Florida coast, it would have solved a lot of problems for me.
So you carry some cloth with you at all times and use it every time you use your knife.
Out of curiosity; why not get a stainless knife instead?
Yes, the obvious
is hard to grasp sometimes...
The DLC issue in the other thread is precisely why I tended to stick with older fashioned Cerakoating, despite its finite endurance, rather than go for some of the newer "harder than hard" vapor coating: I never trusted the notion that a "real" coating could be physically thin, no matter how hard wearing it may be.
On the other hand, the problem with Cerakoating, and other "powder-type" paint coatings, is that too much emphasis is put on surface preparation (sandblasting) and paint adhesion, and not enough on the paint's
own surface hardness. The Chris Reeves one piece knives are somewhat like that. The reality is that a lot of cheap paint coated Chinese knives have a harder paint surface, while being carelessly applied to non-sandblasted surfaces: They do occasionally flake as a result, but I have found the harder paint surface, in the end, wears down noticeably slower from typical non-batoning knife uses...
Stainless doesn't really need any coating, especially if a tight sheath is going to put rub marks in the paint, but it is always nice to know you are overkilling an issue... Better than defending the notion of a finish that is a "vapor" or even that
causes rust on stainless(!), in any case...
Gaston
