I'm curious among those who use DMT sharpening stones: have you tried both the interrupted surface (those with the metallic surface on the stone with recessed holes to catch the sharpening residue) and the continuous surface stones, and what do you see as the pros and cons between the two types?
I currently have 2 of the 10" duosharp stones (EC/C and EF/F). These seems to work great in general, I love how they work. But one drawback I've noted with the interrupted surfaces: it's hard to sharpen portions of your blade right up to the VERY edge of the stone (because part of the metal wraps around the edge/corner, which keeps you from sharpening right up to the edge). What this means is, depending on the design of your blade, sometimes it's very hard or impossible to get that last little bit of your blade sharp right near the handle, since you can't go right up to the edge of the stone.
I would be interested to hear if anyone else has observed this issue, and if you've found effective ways to work around it with the interrupted duosharp stones (or if you've decided to switch over to the continuous stones to get away from having part of the stone covered with those metal coverings).
