- Sep 29, 2008
I disagree. If you spend enough time on the finer grits, you'll eventually get all the way to the bottom of the deep scratches anyway. It might take a little bit longer, but you'll get there, and you'll have removed less metal in the process.
If you're removing less metal, then I refer you to my previous post. Why not just use the finest grit available?
I would argue that the difference between working up through successive grits and starting at the finest you're removing marginally less metal. Such a minute difference would be insubstantial.
