I Sanded my scales and I'm not disappointed. Totally tore up a pair of jeans I have. I simply used fine grit. Worked out splendid for me
Looks? Not at all. The only difference is now I can pull it out of my pocket without having to put my underwear back on.
Well if sanding isn't the way then I may just take the scale off and rub it aggressively against some denim to see if I can help speed up the process, I will figure out something.
I do just this, but use an old piece of carpet. It takes a long time to notice a difference, but really smooths the scales out nicely without removing any of the pattern.
They're still grippy afterwards, but they don't feel like 40 grit sandpaper.
Why not just bend the clip out a hair? .
I've said it before, and I'll say it again...It's about the knives, not the trousers.Tight pocket clip is a must for me.
Be a man and ROUGH it out. ^
Cheers
I dislike a non-contacting clip, they tend to "buzz" and otherwise make the knife feel "loose". Today I received a Jungle Commander and must say the "grippyness" is really cool. But I can tell my pockets would cease to be pockets if I use it as it is.
I prefer to just leave the g10 along and let it were down naturally.
I don't wave my knives that much though.
^^That's Funny! I used a small piece of 120 grit sandpaper for reducing the grip of the G10 under the radiused portion of the pocketclip as mentioned by gooeytek. I just lift the pocketclip a little (still installed on handle) and slip the piece of sandpaper between the pocketclip and G10. Then release the pocketclip letting it clip the piece of sandpaper with it's own degree of pressure against the G10 withe the grit side facing the G10. Then grab that piece of sandpaper and pulllit through/out of between the pocketclip and G10. A pull of about 1" can remove quite a bit of material so go a little bit at a time and test the results. The other thing would be to bend the pocketclip and thus reducing it's grip without having to sandpaper at all.
