- Jun 23, 2008
^^This.
Boker makes a heap of patterns in 440C and Entrek as others have mentioned.
440C is and always has been a excellent steel. It was the premium goto stainless at one point, until it's reputation was harmed by a lot of cheap imported junk marked "440". When well treated I would put it up against any steel out there today and I doubt many users would actually notice the difference.
n2s
Polished 440 is TRULY stain/corrosion/rust 'proof' compared to other stainless in my experience. ATS-34 comes a close second.
And there you have it. An example of why 440C gets a bad rep. It's reputation is soiled by being confused with "440". Knives marked "440" are almost never 440C.
I think, he was referring to the fact that Japanese developed more steels specifically for knives compared to western makers. Crucible did S30V and that was a big deal few years back. Can't say it's a super steel either. Carpenter also is researching, CTS-BD1, CTS-XHP, although later wasn't specifically for knives. Other than that, yeah there's plenty of very good alloys, but original design was not for knives.I beg pardon? super steels are primarily Japanese? Nonsense.
There are very advanced alloys from Crucible (USA), Bohler (Austria), and Carpenter (USA). There are also some from Japan.
And do you have any doubt that given the same geometry super steels will outcut the same GEC? Like you say, geometry has a huge impact, but because someone makes super or not so super steel knife with bad geometry is not alloy's fault, but the maker/design issue.GEC uses 440C in their stainless models. Does an amazing cutting job. Their edge geometry is outstanding and I find the blades will out cut others made of fancier alloys. At the end of the day, blade and edge geometry have more impact on cutting than blade steel. Proven fact.
n2s
I had a Boker Plus Titan Drop that out of the box wasn't very sharp, it wasn't because of the steel I believe, it was more because of the obtuse edge. I backed the edge off to 20 degrees on each side, which was very easy to do BTW, and it was hair whittling sharp.I usually like Boker knives and have a bunch. I have found the 440C Chinese made models are about the worst knives in 440C I've experienced. The grain structure is terrible. I have better luck with the taylor /schrade brand whatever steels, or rough riders. The Chinese made 440C blades is more wear resistant but try putting any kind of sharp/thin edge on the knife and it'll fight against you every step of the way. It doesn't want to get sharp, not cut. It rolls pretty darn bad and stays that way until it flops over to the next direction and begins again. Stropping can get the burr but it doesn't help much in whole scheme of things. Their "magnum" branded cheap damascus does better, as does their German 440C. The 1070 blades do really well when it comes to sharp edges , but you won't find that steel in the chinese made knives.
No, I have no problem with Chinese made products, nor do I find the products made there for Spyderco, Benchmade, and the above two inexpensive brands. The Spyderco and Benchmade 8C, and Benchmade 9C knives do very well in the edge department. It's too bad as Boker has some of those knives with nice wood, and even titanium models with that lousy steel.
Old Gerber and Buck models in 440C are much nicer, as is the newer benchmade and spyderco production knives.
It's not just the alloy in the 'unnamed' 440 alloys. If they won't tell you exactly what it is, there's a good chance they aren't giving it the best possible heat treat. 440a or 440b with top shelf heat treatment is more than just serviceable, heck, look at what Paul Bos has gotten 420hc to perform like.
I understand possible reasons to not want to buy from main land China, but curious about Taiwan? It's not a communist country, and they have very good manufacturing capabilities.
