I agree a fully serrated edge on one side would make sense as an option.
  I think the grind issue you mention on the SOG Paragon is an inherent problem with the overall blade design: The blade is thick, and the pattern has no edge "flare", so the edge never gets far enough from the central spine because the blade gets continuously narrower. In theory it should cut better near the handle, but that is ruined as well by the "flaring" center grind, near the blade's base, which again brings the grind closer to the edge... The Gerber Mk 1 had a similar issue of lacking blade flare, but without worsening things with a center blade grind "flare". (Interestingly enough, these Mk Is could vary in blade length from 4 3/4" to 5 1/4"! Quite loose tolerances...)
  The EK daggers had a really broad center grind on a narrow blade throughout, not even with deep hollow grinds I think, and I could never understand why they were a popular design or how they could cut anything.
  The Cold Steel Tai Pan illustrates how efficient at cutting a double edge design can be, and in general I would say a double edge dagger without some edge flaring, and/or deep hollow grinds, is not really trying.
  Still think by far the biggest issue with these knives is dulling one edge or the other on drawing from traditional sheaths...
  Gaston
