- Sep 16, 2019
I just figured out what your measurement was. As far as I understand, you checked the flat of the knife and your phone read -18, then you set -8 (only 10 degrees up). That would be an insanely low 10 degree sharpening per side. If you wanted a 20 degree per side edge, you would have needed to go to +2 degrees on your phone reading. You eventually sharpened at -2, which according to what I reckon, was 16 degrees per side...a very ambitious angle for a big blade like that, which probably has about a 25 degree factory angle.
But again, try measuring by zeroing first on the clamp holder and then measuring on the stone holder. If you can zero your phone.
And remember, a 20 degree edge we normally talk about, is 20 degrees per side (so that would be 40 degrees INCLUSIVE). I think you tried 20 degrees inclusive, which is a 10 degree sharpening angle.
