- Sep 23, 2014
how did you determine it cuts better?I disagree. A polished edge performs better its just it can be a dimishing return on time put in vs acceptable performance needed to accomplish a task.
The fact is, a super-fine, hair-flicking edge is not appropriate for every task. The finer the edge is, the faster it's going to dull if you are cutting tough materials. I wouldn't want a scalpel-sharp edge for cutting roofing paper.
From use. What's your rebuttal?
https://en.wiktionary.org/wiki/rebuttal said:The act of refuting something by making a contrary argument, or presenting contrary evidence.
Isn't the first step of sharpening to asses the condition of the edge , or set the condition of the edge?
I think I would ask : is this sharp enough for your purposes?
Some can get knives sharp enough to shave face hair comfortably ... but I doubt a lot of those guys need that level of sharpness![]()
They all take damage the same. It's more disheartening on a polished edge because of the extra time put to sharpen. But I enjoy the performance of a clean polished apex on a knife or axe. Angles? Time? Not sure. It just works better.
Technique is huge when sharpening. Some people don't like polished edges because they unintentionally round the apex making it slice poorly.
If I didn't notice a difference then I'd be with ya and wouldnt put in extra effort either.
There is a difference with those materials mentioned as well.
Paper cuts smoother with polished edges there is an audible difference and the cuts are visably cleaner.
Hairs will "pop" off the arm versus snaging and tearing
Carving feathersticks or woodworking is a joy versus tedious hand cramping misery.
Haha, probably just me. I'm obsessive.
That's a huge variety of coarse grits, sandpaper?
Kinda of, if I Sharpen a knife on a extra coarse DMT stone and attempt to shave arm hair it does a poor job and only seems to catch hairs snag and tear them rather then cut or slice them.
Getting back on topic should one strop?
Heres a test for you Bucketstove.
After honing on your finest stone,
Take a piece of paper ( newspaper works best)
Place it on something hard and flat.
With light pressure, alternate stroping passes on each side for 20 passes total.
Lightly draw the knife edge through a piece of softwood.
Tell us the result.
Does stroping work?
Ok, I went ahead and tried it again
20 passes per side on newspaper
no improvement, no degradation, no real change
shaving ability same , decent scrape shaving on arm/leg
slicing ability same , whoosh on a slice, slightly noisier on closest approximation of a push cut
so I went and did another 20pps, again no change
and I did another 20pps, and again no real change
I did them slow and careful ... being very careful for 120 passes is, well, a lot of focus
then today, I did another 20pps on painted side of cardboard , then another 20pps ... no change each time
I imagine I don't see any change because I cut the burr off on the stone
so stropping on low-abrasives like paper/magazine/cardboard
doesn't noticeably improve the edge that remains
Ok, why/what am I doing wrong?No disrespect intended, but you must be doing something wrong. I can get noticeable improvement just by making 20 passes on my palm with my razor. I let my face be the judge, and if one side hurts to shave and the other (after stropping on my palm) doesn't, I have to say that stropping made a big difference. I will admit that I won't try this test with a machete...![]()
The sharpness I've achieved so far is not enough for my face -- stropping hasn't improved that
