Chiral, I think maybe you are misunderstanding/misinterpreting a few things. ...
...Remember our knives (carbon steels anyway) are tempered in the 400-450 range usually. That temp can be reached pronto, on an edge, with powered sharpening if not careful.
Chainsaws and files are not on the micron level of a knife edge. No where NEAR as keen.
Straight razors......stropped, by hand. Yes, dry, but by hand. Not a powered stropping system. ????????? Would YOU power strop your straight razor? I didn't think so. And stropping is misunderstood by most everyone out there anyway. Not relevant to this discussion, but very true.
It's good not to buy into everything someone says. But Mr Landes has done WAY more study than anyone out there. He has done the tests and came up with results. Much more than I can say for myself for sure, and 99.9% of the rest of us.
"but i will still advocate that users avoid power-sharpening except for major undertakings" BINGO we have a winner. Now you are understanding the reasoning of my post. I'm not here to argue. I'm not here to say, "Look at me". I'm here to offer info.
To those who are interested in the powered sharpening systems, again, just understand they have SEVERE limitations on what you can do in sharpening a knife. There is NO FREAKIN way that I would use one with fine grit belts for sure. NO WAY. The only time I consider powered sharpening is when I have an edge thickness on a rough/tough type blade that needs to come down. Say a chopper with an edge of .035" or whatever. I might consider my belt grinder, with very coarse belts, never apexing. I would probably use a 120 grit belt and barely approach the apex, then switch over to hand sharpening. Just NO WAY would I apex an edge using powered equipment. To do so, in my opinion, is asking for it. Now some might argue, "What difference does it make on a chopper?" To which I would agree. On my White steel kitchen knives......NO FREAKIN WAY.
I'm sorry if capital letters offend you. They're a quick, good way to show my emphasis on certain phrases!
I have no problem with capital letters, I use them all the time :thumbup:
1) Landes related a story of a friend burning his eye from
hand-sharpening a blade and having a bit travel the distance ... His study results need proper interpretation regarding the limits of their relevance, just like his edge-stability tests. Much respect, yes, but also a healthy level of skepticism and in depth interrogation.
2) Cutting cardboard and stropping at a very fine grit both generate a LOT of heat VERY quickly, because the heat is generated exactly the same way as when power-sharpening - i.e. through friction
along the bevel faces. If your edge is getting sharper and you aren't using a coolant, then your apex is also getting hot, much hotter than the surrounding material through which it dissipates. Frictional heat generation is reduced through less application of force, e.g. fewer and more precise surface contacts as provided by a fresh belt. Stropping
by hand is often done at relatively high speed (lots of friction) and VERY fine grit = heat generation. What is "burnishing"? Rubbing-action that generates
frictional heat until the yield-strength is exceeded (maybe because the apex is being tempered softer?) and the material plastically deforms ... resulting in a finely polished bevel that is
maximally sharp!! I can cut a LOT of cardboard and quickly with a knife and not lose a shaving edge, depending on the steel, despite the heat generated. Paper-wheel sharpening/polishing is common ... lots of complaints about edge-performance?
My point - while power-sharpening CAN result in a "burned" edge, even use and HAND-sharpening can generate heat sufficient to potentially impact the temper at the apex... and that is not necessarily detrimental. The real TEST is to sharpen whichever way and see if you repeatedly notice an impact on cutting performance. If there is NOT an obvious impact, then the heat being generated isn't relevant.
3) Chainsaws are
powered chisels, they should be sharpened accordingly for maximum performance, micron-level keeness is advisable. Under-sharpening results in decreased performance, increased load on the motor, and increased damage to the chain. Who told you it was otherwise?
Scalpels - How it's Made: (power-grinding at ~2:30, i can't see any coolant )
[video=youtube;V89F7_MLKqM]https://www.youtube.com/watch?v=V89F7_MLKqM[/video]
