- Apr 3, 2011
Does anyone have the link to Roman Landes study where he discovered these extremely high localized temps? Every time I do a search all I get are more references back to it, but never the study itself. I've always been curious how one could distinguish between the temp of the edge at the micron level and the temp of any adjacent ground off swarf or even bits of abrasive for that matter. The tale of the burned eye - does not seem possible that a piece of metal that small produced by hand sharpening could retain that much heat traveling the 18 odd inches from the workpiece to the eye, and have enough heat energy left to overcome surface moisture and still burn the eye.
For myself I have never noticed any difference in edge retention based on dry, wet, or powered sharpening, at least none that was apparent relative to other considerations. A difference of 4-5 points Rockwell C generally makes a notable difference in edge holding, I'd think a loss of same for any reason would be fairly obvious.
Not that heat buildup isn't a concern, where there's smoke there's fire and powered sharpening needs to be approached with care in any event. But as pointed out in earlier responses - I've noticed a fair amount of heat generation while using various cutting tools, in some cases far more than I've ever detected while sharpening, even on powered equipment.
It's probably somewhere in here... have fun lol
