- Oct 27, 2005
I do, cause I just did.
I've always made guards out of a single piece of brass, nickel silver, etc. I decided to try my hand at a stacked multi-material type guard. Starting from the ricasso I had 1/4" nickelsilver, then three spacers (red, white, red), then 1/4" ebony, then three more spacers (red, white, red), then 1/8" nickelsilver.
I had it all epoxied together and roughly shaped. I even epoxied two small pins from the handle side down into it, that went through all the material and about 3/4 of the way into the 1/4" nickelsilver that would be against the ricasso. This was meant to hold it together while I drilled it. Well, at least that part worked. but...........
Then I marked it carefully to begin drilling the holes for my slot. I drilled the first hole, and then took it out of the drill vise to look at it before drilling anymore holes, and my hole had wandered way off by the time it got to the bottom. Aaaaauuuuurrrrrrghhhhhhhhhhhh!
It's soooooo far off that I have to start over. I really suck at making guards right now.
When I make the new one, I'm going to carefully drill and hand file each slot starting at the handle side one by one before epoxying it all together.
Any other suggestions? I need to shorten my learning curve here.
Ickie
Ickie
